Group: DynoMotion Message: 1318 From: quelisto Date: 6/22/2011
Subject: Amendment to previous query about header files
Apparently the problem is manifold:
a) You have to specify the path in the #include statement; this is pretty frustrating, the complier should be smart enough to look in all of the KMotion folders, or all the header files should be in one place!
b) The following header files that StdAfx #includes are nowhere to be found:
afxwin.h> // MFC core and standard components
afxext.h> // MFC extensions
afxole.h> // MFC OLE classes
afxodlgs.h> // MFC OLE dialog classes
afxdisp.h> // MFC OLE automation classes
afxpriv.h>
I also cannot find stdlib.h, math.h, etc.
What is going on?
Group: DynoMotion Message: 1321 From: Tom Kerekes Date: 6/22/2011
Subject: Re: Amendment to previous query about header files
It sounds like you are attempting to run Windows C++ code on the KFLOP board?  The C Language programs that run in KFLOP are very simple and are limited to the functions listed in the single header file KMotionDef.h (actually that includes another small header for a few PC-DSP common definitions).
--- On Wed, 6/22/11, quelisto <quelisto@...> wrote:
Subject: [DynoMotion] Amendment to previous query about header files
Date: Wednesday, June 22, 2011, 8:20 AM
afxpriv.h>
What is going on?
Group: DynoMotion Message: 1322 From: quelisto Date: 6/22/2011
No, I'm just using the Kmotion program. We don't have Visual Studio, etc. All development is occuring inside the "C program" application of Kmotion475.
But the issue still remains as to why the compiler can't find the necessary header files...I just don't understand this. Is the compiler assuming that I have an install of Visual Studio to supply the needed stdlib.h and the various afxxxx.h files? I just installed this software yesterday, so unless I'm missing something I would htink all of the necessary header files would be somewhere in the Kmotion directory or subdirectories...but htye are not, as far as I can tell.
> From: quelisto <quelisto@...>
> afxpriv.h>
> What is going on?
Group: DynoMotion Message: 1324 From: Tom Kerekes Date: 6/22/2011
The C Programs Screen in the KMotion.exe application and the associated and included TCC67 compiler can only be used to write C programs that execute in the DSP Chip on the KFLOP board.  If you wish to write Windows programs that execute on the PC you will need something like Visual Studio to do so.
Subject: [DynoMotion] Re: Amendment to previous query about header files
Date: Wednesday, June 22, 2011, 10:55 AM
> afxpriv.h>
> What is going on?
Group: DynoMotion Message: 1328 From: quelisto Date: 6/22/2011
No, I'm not trying to write Windows programs for the Kflop board.
I simply want to compile my code in the "C programs" environment.
Whenever I try to #include stdafx.h, the compiler fails, telling me it cannot find the various afxxxx.h files. the same program exists for KmotionDLL.h...the compiler cannot find various header files.
Again I am NOT trying to take a .cpp file from visual studio and compile it, I am t\just trying to compile stuff written with the C programs window. I am using only functiuons that I've seen you use in example code. This SHOULD be working, but something is amiss here.
> > --- On Wed, 6/22/11, quelisto <quelisto@> wrote:
> > From: quelisto <quelisto@>
> > afxpriv.h>
> > What is going on?
Group: DynoMotion Message: 1331 From: Tom Kerekes Date: 6/22/2011
stdafx.h is the main Microsoft Visual Studio header file for writing Microsoft Foundation Class (MFC) applications for Windows
Date: Wednesday, June 22, 2011, 11:14 AM
> > afxpriv.h>
> > What is going on?
